Backing plates or not
890man
Thousand Oaks, Ca.
So I am almost ready to do my fj60 disc brake conversion on my fj55. I have read that some of you guys don't use the backing plates. Why leave them off in the conversion. Wouldn't they offer some type of protection for the components.
I also remember something about an adapter bushing that will allow my tie rod ends to work in the 60 knuckles. Where would I find these. I plan on doing 4-wheel disc first then scout p/s. After both are on then I can upgrade to stronger tie rod ends.
Thanks
Don't they take up about 1/8" of space as all the knuckle pieces bolt together? If you take them off all together you'll need to put a spacer of some kind in there so you can bolt the hub dust seal onto the outside of the knuckle.
Also, isn't there a break line 'T' riveted to the back side of them going from the flexible line to the short caliper line? Maybe that's only later 40 front ends.
Either way, if you remove them it's one less piece to take off on the trail to replace a broken f-ing birfield.
Good luck!
I personally don't like to use bushings, I take the knuckle arms to the machine shop have them filled and retapered for the other tie rod end sizes, I haven't had any problem with them at all. Cheers, Larry
Hi All:
when I did the disc brake swap on my '74 FJ40 the donor parts (from a '78 BJ40) came loose in a couple of boxes. Upon re-assembly, my buddy and I discovered that one of the backing plates was missing. I have been running these front disc brakes without a backing plate on one side for the last 5 years or so without any problems.
I am not familiar with the front disc brakes on the *J60/62 Series so I don't know if this is equally valid with those parts.
Good luck on the brake swap project!
Alan
Sounds good, I may just leave them out. there is a t-fitting on the backing plate but if I just go straight from the hard line to the caliper with a longer ss line, it shouldnt matter.
Hey brew8, do the weld in new material to the holes then retaper? I am just looking to get by for a few months until I get the parts and do the p/s conversion. After that I will figure out what rod ends I really want to use. I dont want to have the truck down too long between upgrades.
