Back Window Stuck Down
Kalispell Montana
Hey Guys I am trying to find out if there is a way to pull the back glass. It is currently down and I am pretty sure the gear shredded as I hear it trying and can even see it after I pulled the cover. The issue is I do not want to mess up anything and wanted to get some info before I start trying to pry the glass out so I can fix it. Any input? Thanks
Carm
I could move mine up and down by hand when my gear was broken, It took a little doing, It was hard to move.
I opened the gate pulled the cover, Slid the glass out(up position) and was able to get to the window motor.
Good luck
Really? Man mine is really in there then. I tried that and was really worried I might just break something. I'll try again tomorrow and see how I do, thanks for the info. It may just give me the courage to man up and get it done. =)
There are two slide type latches at each side that hold the glass and glass track to the regulator. See if you can dislodge those and that will release the glass.
Where abouts are you in Kalispell? I'll be passing through there in mid July.
