back up light switch
Sunny South
i check the wiring diagram for my 71 fj40 and i think stock it only has one back up light, and a RL wire should go from the back up light back to the "back-up light switch" which i'm assuming is connected somehow in relationship to the reverse gear, so that when you shift into reverse it lights up...
anyway my question is how do i access this switch to connect it?, there are 2 wires are dangling down from the tranny and i need to rewire it so it works properly, is it connected to the top of the tranny ? thanks...any info helps
pics would help to i guess
The reverse light switch is in the shifter tower atop the transmission. You could reach around, but it's easier with the tunnel removed.
Yes, there are adjustments and a return spring at the brake pedal. The light switch(s) are not themselves adjustable.
The factoids are contained in the most elemental repair manual.......
