Afternoon Mud Mind!
I'm getting ready to replace the interior carpeting and install sound deadening on my '89 FJ62. I've done this before on another '89 FJ62 with great results and enjoy the process. However, when I removed the old carpet adhesive and gunk last time, I did NOT use the dry ice and alcohol method. Does anyone have wisdom on the right way to do this? If you can share I would appreciate it.
Second: I replaced the head unit with a double-din Apple Carplay unit which is less period correct than I would like but makes the car much easier for my wife and son to drive which in turn increases its life and utility here with the family. Final step is to install and connect the back up camera. I hate the idea of drilling into the tailgate but I think that's what's required. I have the option of either a license plate frame camera or a standalone unit, slightly bigger than a matchbook. Does anyone have advice/wisdom to share on exactly WHERE to put the hole and how to run the camera wire? I can (obv.) run/secure it under the truck and then pop it up towards the rear OR as I'm about to replace the carpet, I can run it under the carpet the length of the truck.
Any/all advice and suggestions are welcome.
Thanks!
E
Thanks!
E
