Axles click when turning
Ok so when I turn I get this loud clicking and it has gotten progressivly worse over the past months... Is it the birfs? Knucles? Bearings? What is it and what do I do?
I know this one,:) This could be your birfields, there are a lot of threads on this one.
Have you tried searching yet?
Also could be wheel bearings - with wheels pointing straight ahead, lift your front off the ground and see if you can rock the wheel by pulling on the top while pushing in the bottom.
I"ll do more of the search bit... What do you guys think about longfields? Do I search for birfield rlated links or what would you type in for the search criteria?
Ok what I had originally thought is the birfs, I just wnated to post up and get opinions... From a few other posts it looks like I will need the birfs replaced but what else do I need when I do birfs? If I buy the longfields what else will I have to also purchase to do the job? Bearings, knucle re-build kit, new abs stuff? Who has done this and what else do I need to know?
You may not need to replace the birfs. You may be able to just do a through overhaul/service and get by without the extra cost.
CruiserDan has a very inclusive list of what you will need to do a complete service if you do the job yourself. PM him for a list. I highly suggest doing this yourself, it's not that hard, but very messy.
I should also say, that the info is here on the board, if you don't want to clutter his inbox. search under front axle rebuild or service.
