Axle Swap Question
93-97 are interchangeable.
Overland,
Your PM box is full. I'm trying to reply back to your pm but it gets kick back.
If you want to get locking axles, then try this website www.car-parts.com :grinpimp: Good luck, they are still pricey even with high miles.
Curious, why bother???
I'm thinking that for you, ARBs would be far easier, stronger, roughly the same money and less work. Just sayin'.....
I know! Get ARB's and you can get lower gears at the same time. It's no brainer. Do it!
I have a complete set of front and rear lockers that I am going to be selling shortly. These axles are complete, rotor to rotor with 110K and little to no rust. I have the front factory wiriing harness, ECU, Diff switch and CDL switch. Axles will run $750 each, wiring harness $30, (both switches and ECU for $100) (package deal).
If I part this thing out and go do individual pricing, the switches and ECU be more than $100 for all three.
Let me know what you think, my location is 19063.
Thanks for the offer, but it's going to be too spendy. 1500 for axles 300 for gas, food etc there and back 100 for the wiring and switches - I'm at 2000 already and not sure if the lockers actually work (not discreditiing you in any way) then a buddy and I will have to install which will run at least another 200 in shop time for use of the lift etc....
I think these guys are right - ARB would be the way to go - I think I can actute those with my CO2 system and have all new lockers for a very similar amount of money and considerably less of my time invested. Thanks again!! :beer:
Overland,
Just bite the bullet and get the ARB compressor. It will make things a lot easier.
Last thing you want is to need the lockers and not have C02 in the tank.
Alvaro
