Axle swap question
EarthX
Owner of Earth Exploration Technologies
Lake Arrowhead
Hey guys, need a little help.
I have a set of 80 axles that Im putting under my fj60. I plan on using all of the 80's links and mounts, and also lift it about 6". So my questions for you guys are:
1) What should I take into account right now about link mounting. Meaning what have you guys with lifted 80s found out after lifting your 80s. Should I adjust the pinion angle, change the links, ect.
2) What coil spring would you guys recommend?
3)What are my options for a hysteer set up? or is that even needed?
4) Any other suggestions?
:cheers:
All I can say is that if you use the stock radius arm-style on the front, you will have to find the balance (best compromise) between having the least amount of caster to make it drive to your satisfaction, and putting up with driveline vibes even after using a DC shaft.
Go with a custom 3 link up front.
You might get more feedback in Hardcore?
