axle shafts
Meridian, ID
I'm almost ready to put this axle housing back under my rig on my buildup. Anyone have recommendations on who would be the best vendor to build me a pair of axle shafts? I built a full floater rear end with an SOA. I'm using a Toyota E-locker from a 94 FJ80. I know I need 4 1/2 inche spline into the diff... etc etc. Moser was recommended, but I'm open to suggestions. TIA
Chaunce
'72 FJ40 '92 FJ80 '88 Mini
Chaunce
I had Jack at CTM make my custom 300M rear axle shafts in my Land Cruiser. They were perfect, exactly as we discussed over the phone the first time, right out of the box. No needing to cut anything shorter, no needing to dress splines not cut properly, or any other BS. He is a perfectionist and the only place that I would even think about calling to have a custom axle made for me. I have used other companies in the past for projects, including the one you name, and they do not even come close in quality or customer service.
Good luck!
-Steve
Give Dutchman or PIG (vendor on here) a call for your 4340 shafts. I know Dutchman will provide a double splined shaft with a drive hub. Not sure if PIG can make the 1 piece floater shaft. I'm sure Axle Jack could do it too. I don't know if Moser has the tooling to cut an LC shaft's correct pressure angle, they're mostly set up to cut shafts to fit Dana/Ford applications.
