So I setup another rover/toyota axle just in case the last one was bent (the guy I got it from wheels a LOT) I also bought a brand new 3rd so there was no question about the diff.
This is the diff I'm running... Inchworm Gear - Toyota Rockcrawling Equipment
So I still have a slight noise at nuetral throttle when the gears are in float. The only thing that isn't brand new on this 2nd setup are the axle shafts. The shafts are made to fit a 30 spline yota diff, and bolt up to a rover hub.
Here's the question, when I slide the shaft in, it slides smoothly into place except for the last 1/8 to 1/16". I don't have to force it, but I can definitely feel it come into contact with something in the diff. Like I said, it isn't something I have to force, just a little resistance. Shouldn't it just be contacting the splines? If so, then it should slide smoothly into place until it seats on the hub, right?
I'm wondering if this slight difference in length. Is what's causing my problems since that's the only part I haven't changed! If it is pushing on the inside there, could that cause damage? Spider gears? I don't know enough about diffs to tell....
If anyone knows of a fzj80 at a decent price, let me know....
