Axle Service Space
I doubt you'd have room to get the long side of the axle in and out easily. You can measure from the outside of the wheel to the diff to get a rough idea of how much length you're working with when you pull the DS axle out.
Do this and keep in mind that the birf can be kinked to the side a little to allow a bit more room to pull the axle out. I did mine in a single car garage, but I can't remember the dimensions. Make sure to park the rig with UNequal space on each side since you need less room on the short side. That's what I did and I didn't have a probelm with room. You might want to back the tuck in so you can leave the door open while wrenching which will give you extra light and more room to move around the front of the rig. That also allows the brake cleaner fumes to ventilate easier.
I actually just did my front axle service in a garage just like yours but mine was 11 feet wide x 20 feet length.
1st of all, it is super tight, but workable!
2nd, park your LC more towards the passenger side (Garage wall), as the axle on the driver side is obviously longer when you pull it out.
*****IMPORTANT***** Leave at least 33 inches from the dustshield to the wall. You need at least that much space to pull the axle out. Axle will not come out straight, but you should be able to turn the BIRF to clear the space.
3rd- HAVE FUN! IT WILL GET MESSY!
Also...I would if the balls are all gunked up, take it to a pressure wash place first and clean as much off the knuckles as you can...it's a total PITA to do with brake cleaner...certainly not too enviro-friendly but it will make the repair A LOT easier if it's in need of a good cleaning.
