I recently purchased new axle seals (the brass bushings that are press fit into the axle housing) for the axle rebuild on my '65 FJ-40. I immediately installed them into the axle housings without trying them out over the axles. What I found out was that the seals were too narrow to fit the thicker part of the axle (the end that fits into the ball).
I checked with the supplier and made sure that I had the right part for my vehicle. They checked it and said that it was the correct part. When I asked the supplier why the seals didn't fit, they said that they had to be machined to a slip fit. That doesn't make a whole lot of sense to me. However if that is correct, what kind of tolerances should they be machined to? Should I measure the shaft and turn them down to .001" larger than the shaft? Any help would be appreciated. Thanks.
