Seeking advise, I have a 75 fj40 with drum brakes, the front axle seal is leaking greese in to the brakes on the passenger side. I have a seal kit and new brake shoes. And I have been waiting for good weather should be this weekend. I would like any advise or help i could get to fix this problem.
Tear apart the axle, clean everything really well, install the new inner axle seal, repack everything that needs grease, install the new seals and gaskets on the spindle and wheel bearing hub, put it back together and call it good.
I have done everything short of the wiper and inner seal, it's EASY! just pay attention when you take it apart so that you remember how to put it back together good luck
Yes, but...it's the inner seal that is the critical part. To replace it takes an extra 5 minutes once the inner axle has been pulled out. There is no reason to get that deep in the knuckle and not replace the seal.
For okfj40, this is a good chance to switch to front disk brakes-it the same amount of work as doing this repair.
The only reason I didn't do mine is cause I was tearing into it for brakes and not seals, it had brand new bearings and seals when I bought it. Yes I agree for the extra 5 minutes if you suspect that the seal has seen any tiny bit of abuse replacing it is a good idea.
And to come to agreement on point number 2 depending on your year the conversion would only require a little bit of grinding. I have seen this done it takes about 5-10 minutes to grind and the rest is just putting it back together, easy mod.
Thank Guys
I have the axle apart and cleaned it looks like I have a bad brake cylinder, I have ordered 2 today from Cool Cruisers, I should be an expert when it is done, thanks OKFJ40
I have the new axle seal and the new wheel cylinders (pass side) installed and new brakes on the front. But I may have a problem.
When the wheel is tightened up you can no longer turn the tire by hand. I also noticed after driving there was smoke coming from the drum area on the passanger side. Any advised is welcomed. OKfj40
It sounds like you need to adjust your brakes. The smoke is the heat generated from the brake friction heating the drum and burning off oil and other deposits. The adjustment is that sprocket thing on the wheel cylinder. You'll have to adjust both by placing a small flat head screw driver in the back of the plate the cylinders mount to. There are two holes one on the top and one on the bottom that will align with the adjustment sprocket/gear. I believe the manual tells you which way to turn each but if you are not sure you can take off the drum and turn them to seewhich way expands and contracts(check both thaey may be different).
Good luck and I hope I remembered most of what you need to do..It's been a while.
If your drums are anything like mine were you're gonna be looking at new drums at your next brake job, I had BRAND NEW (read right out of the box) and over adjusted my brakes once, they rode long enough to be warm but not to start smoking and it was enough to untrue the drums. I love my new disc brakes they're so much less of a pain to adjust (read: bleed n go!). Can't wait to get my rears converted
I just finished all of this with my 74. Rebuilt knuckles, new bearings, races, seals, repacked birfs...the whole shabang...should have went with a disc kit...I used JT Outfitters...and they are working great but were a pain...I'm glad I went disc...just went out and cruised last night...stops straight! and fast!....
I was going to do the drum rebuild...I sent my front calipers back for rears and used the new drums on the rear. It's not too late....
I was suspecting the wheel cyls would be part of your problem as soon as you said drum brakes. At least you were smart and bought new cylinders instead of trying to 'rebuild' them. I trust you go the axle seals replaced. One of the more enjoyable detailed maintenance tasks to perform on a 40 IMO.
Yes, you should jack the tire off the ground when you adjust the brakes and crank em down til it won't spin and then back em off a couple notches past the point that it rotates freely and you don't hear the shoes dragging on the drum anymore. Evenly adjusting each cylinder is probably important too.
As if the horse hasn't been beaten enough. Get some discs, they are the single best upgrade you can do to your truck IMO, Power Steering being second.
