I recently finished an axle rebuild on my 80 using OEM parts and the kit from Cruiser Outfitters. I followed the directions that accompanied the kit which I'm assuming is the same as the FSM. Everything went well and I used several brand new parts including two Toyota axles and a Nitro Birf. I also torqued everything to FSM specs and I measured the preloads with a fish-scale. The fish-scale specs were within Toyota specs however they were on the light side. For example: the wheel bearing preloads for Toyota are between 6-12lbs. My preload measured around 7lbs.
My problem is the passenger side wheel has some play in it from the 12 o'clock to 6 o'clock position. Not much play but enough to feel it. For folks that have run into this issue: do you think it is the trunion bearings or the wheel bearings? keep in mind I did use the original shim that came with the top trunion bearing. Do you think I should have tightened the wheel bearing preload more so It was reading closer to 12lbs on the fish-scale? My spindle has some slight wear but I didn't see enough to be too concerned.
Thank you for any help you can provide!
