Hey a little help here, My front axle is making a grinding noise when I am in reverse this just started this morning. You drive forward and there is a little noise but not much when you put it in reverse you get binding to the degree that in idle it will stop the truck. By the way it is a 1997 LX450/FZJ80. I have recently had the DBA rotors installed on it and the DIff high switch. I do not think either of these are the problem but just so you know. If I put the truck in Neutral and push it it does not make any noise this is tranny and transfer case neutral. I did not push it backwards when I did this. I would appreciate some help thanks guys.
