axle/leak advice needed
I don't see any sign of trouble. But then again, I don't see anything - no pic showing up for me :frown:
2nd upload try
another try at pics
birf soup
If they turn to grey soupy stuff and you have oil/grease spots on the floor every time you check then its time for a rebuild.Marlin Crawlers kits with his big seals work well. IMOP , you don't need to do the rebuild right now??
I just had them done in May 2007 and I'm being told by a different dealership that they need work (they didn't know I had them done last year).
Birfs
Clean the crud off and rag them down and see if they get oily and cruddy again .In the mean time drive your cruiser and be happy.If you just had them done what does that dealer say about this???
From the exterior they appear fine.
the dealer that serviced it most recently (had it in for a slight scraping sound coming from driver front wheel) said there was leakage and sent me those pictures from the shop. i told them i just had them done last may and they said i should take it back to the old dealer and have them fix it.
so i took it back to the old dealer from may '07 and they said (without knowing my recent diagnosis) that they were fine. so now i don't know what to think...
Slight seepage is to be expected. When great big globs of grease start showing up on the wipers, or you start leaving grease/ oil spots when you park- then you need to address it.
The wiper seal is just a piece of rubber and felt- it's not going to keep everything inside the knuckle.
