Is there a way to tell what year a front axle from a Fj40 is?
I must be working on a lot of older stuff as they seem to all be through the hub.lug studs through the hub = older design.
Hi
If it still has the original brake hoses. There is a small rubber ring on the hose that has DOT and a date like 3/76 on the ring.
Once you get it apart the pinion will have the teeth count on it and the manufacture date like 3/76 on the shaft between the two bearings.
Thanks jb
Actually, looking more carefully, they may not be through the hub..
I think what Mace was talking about was the rotor; wheel studs through the rotor or not through the rotor.
Those look like the correct wheel bearing hub and rotors for a 1976 front disc brake axle in the USA.
You can see a couple of the six threaded holes that are used to retain the rotor to the wheel bearing hub for the 08/75 to 07/80 wheel bearing hub and rotor combination.
