Axle codes
Trying to learn more about FJ40's before I buy one. Two questions.
Where is the axle code located for a 69 or 73FJ40?
Is there a code for each differential so I can tell if it's open, LS, or Locking?
Thanks for you help.
I am sure someone will correct me if I am wrong but I am not aware of any "axle code" like you find on Dana axles. If you are looking for strength in a LC axle you will not want a 69 which is the weak "ball and claw" design. If you really want strength you will want to swap in 79 or later knuckles to get the larger (stronger) pattern.
Welcome to Mud! You should check out the FAQ and the Technical Links above for lots of information about LCs.
I think '67 was the last year for the ball and claw.
Ed
Although '67 is supposedly the last year for the B&C, some '68s had ball and claw too - including mine. Has '68 dash (dash pad, windhield knobs instead of levers, etc.) but B&C axle.
I got this info from rustybrain.com. The owner isn't sure what he has and I was looking for a way to determine the type of differential and pass it on to him.
9.1 AXLE CODES
Axle codes are never located on the axle housings themselves. In trucks
manufacturered after 1976, the axle codes are located on the build plate
which can be found inside the engine compartment. The pinion (and sometimes
the ring gear have the tooth counts (from which the ratio can be calculated)
stamped into them.
Example: K 08 2
^ ^^ ^-2 spider gears
| ++---4.11 ring/pinion ratio
+------9.5" ring gear
First digit: ring gear size
G 8"
J 9.25"
K 9.5"
