took the 72 40 for a quick spin today and, when i got home i saw axel grease inside the left rear wheel. what seal do i need? i am a learn as i go mechanic, so sorry for the uneducated question.
Well-you are about to learn about c-clips and stinky gear oil. The only tip I have is to not take the easy route of replacing just the seal. The bearing is likely bad as well and this would be a good time to replace. Kragen has a big slide hammer you can rent for free and makes quick work of getting this bearing out of the axle tube.
For gear oil-I use the cheap stuff. THe Coastal brand at Auto Zone is close to $1 per quart in the 5 gal buckets and has kept my FJ40 happy for years. If you really want good stuff, the Mobil 1 at $7 per quart is great but I'm not sure it's measurably better than the Coastal.
Last tip-use only genuine Toyota seals and grease up the lip and the seal surface on the axle before you install.
