Auxiliary tank question..
Corpus Christi/Austin, Texas
With a 400 S.B.C. and a 13 gallon tank I think I may need an extra gas tank. I would really like to get one, but really don't want to put a hole in my tub. Does anybody have an auxilary tank and have a filler neck some else than coming through the tub?? Extra tank being between the frame in the rear..
I was thinking about putting the filler neck in the inside of the rear wheel well. Anybody done this??
Other options??
TIA
-my64fj40
If you run a top I wouldn't do it, the fumes wouldn't be good. Also do you want to possibly spill gas all over you gear in the back on the way to the hills?
It would still be on the outside..
Inside in the rear fenderwell, like behind the tire, not inside the cab.
VTFJ40 nice tank ! my64fj40 just painted his tub and has the early tub with the cool tool box under the seat ! I'm in the same boat and don't want to cut up the body at this point ... like to see some options too .
....Dusty :grinpimp:
With my lack of experience in this stuff I might be missing something, but if placed where you suggest how do you deal with dirt and, on occasion, a good layer of mud on and around the filler opening? Too bad there's not enough room to place primary and aux. fill tubes next to each other.
I dont' understand how you'd mount it inside the rear wheelwell without cutting into the tub at some point. Either you cut from the outside, or you have to cut the inside and have the fuel tube running inside.
I'm not sure what the fuel input looks like on your year, but would it be possible to put a splitter valve somewhere in there somewhere? So you could still fill it from the same input, but have it going to two tanks?
I saw someone on this site with a later model year use a factory door cover for the rear fuel tank opening. Looked really nice and original. probably can find it using the search funciton.
