Auxiliary Light Switch Contact Question
Pennsyltucky
I have what I hope is a quick question--I'm in the process of wiring up auxiliary driving lights on my truck and I'm using a Tundra/Tacoma (?) switch I sourced from CDan (part # 00550-35976). The switch has 6 possible contact points on the back with spade terminals on positions 2,3, and 4. I'm not sure which is positive, ground, etc.
Can someone help me out?
I did try the search but was unsuccessful.
Thanks!
Thanks--this is the Toyota switch--wonder if it's the same? If so, 4 would top, 2 would be middle, and 3 would be bottom--using the indicator light as a reference for top.
Oh, if it helps, I am using this switch in conjunction with the Auxiliary Light Harness from Slee. So, I am trying to figure out which connectors the red and yellow wires go to on the Toyota switch. And if I have to use the third connector for anything--if so, what?
Feelin' kinda dumb when it comes to this electrical stuff.
Hey Lugboot,
Did you figure out the wiring for the Tacoma/4runner aux. light switch (00550-35976)?
I'm in the same boat and it would be nice to know going in what terminal does what? I've also got Slee's Auxillary Light Harness connected to Slee's 9005/9006 Harness (the high beam trigger to be specific.)
In order for my auxillary driving lights to come on when I hit the brights the switch will have to be 'On.' But I don't want the amber light to be illuminated constantly, only when I turn the brights on and the auxillary lights come on.
