auxiliary fuel tank
Philipsburg PA
So i have been rolling this idea around since I have started planning for a rear bumper and a duel swing out. First swing out will be for my spare tire (I have to deflate my 32" spare becouse it hits my trailer hitch, wich I use weekly), the second swing out I was going to use for a cooler rack/work or cooking platform. And with the empty space where the tire was, I thought to build a 15 gallon auxiliary fuel cell. I googled it and I see others had the same idea but not much has been posted since 2010-ish. I see I can buy a kit for an arm and a leg. But im poor. Oh, and im also a welder and fabricator. what im looking for is practical ideas as I might start this before I do the bumper system
What I have allready pondered.
-I know, 15gallons isnt much, but 20gallons is too much
-it might get hit with rocks from time to time (15g isnt very large)
-i dont want to create a potential mechanical problem
-im a welder, not a mechanic and I know very little about fuel systems
what I could use some input on.
-how do I get fuel in my new tank
-do I really need a fuel gage
-how do I tie it into my existing fuel system
-how to I bypass or turn off the existing fuel system
-can I use a simple, external fuel pump
Im hoping to find a basic install kit. Maybe using some OEM parts? I read somewhere that an auxiliary tank was an option at one point. This is a modification that will surely come in handy.
Any thoughts on pumping it both ways with external pump(s)? ie. pump it from the main tank to fill the sub tank, then pump it back to the main tank when you need it. Something like this could fill the sub tank from the main tank in about 8 minutes - short enough to wait at the pump and refill the main when you're done. http://www.ebay.com/itm/110-Gph-14-PSI-Universal-Electric-Fuel-Pump-/351385791012
Not sure if there are reversible pumps, so that you could get by with only one. Pumping from the sub to main could be slower - just flip the switch while you're driving.
If you do it this way, you don't have to mess with the existing fuel system from the main tank to the engine. You would have to get a line into the main tank somehow.
I think you do need some kind of gauge for the sub tank though and a bit of electronics to shut off the pump(s) when either of the tanks run dry - I think these pumps are usually cooled by the fuel flow and you'll burn them out if they run dry for long.
No expertise here and don't know how feasible it is.
Wow. Thinking outside of my little box. What a great idea! You see; I dont really need an extra fuel tank. I simply want fuel "storage". My last rig had a gerry can and it was a pain to transfer fuel. Also storing the fuel in plane sight of where we cooked and ate never set well with me. So all I need is way to tranfer fuel from my storage tank to my fuel tank. Even if I had to run 2 individual pumps on a 2-way toggle. No big deal! And a universal sending unit will let me have a fuel gage that I could hide in the console or glove box.. im glad you brought me back to earth. If this project got too complicated, or expensive I would have ditched it in fear of hacking it all to hell.
thanx! This project now seems very basic and budget friendly. Yes, ill have to drop my existing fuel tank to run the proper fittings, but thats okay. I have a vapor leak ontop of the sending unit that I can fix and also replacing the old fuel pump would make me feel better.
I've been casually thinking about this idea for a bit also. Getting the fuel into the main tank may not be hard - I think others have done it by splicing into the fuel return line with a one-way valve on the engine side. It's getting the fuel out of the main tank that's more difficult. Not sure how to do that easily. Have to consider venting as well.
As far as pulling from the main tank I thought to just poke a hole in the top of the tank and use good pressure fittings and a hard pipe 3/4 of the way down. Is that a bad idea? I've also thought to just buy a 15gallon plastic tank because it comes with the sending unit, universal straps(probably won't use) and is vented. I would still have to fab a skid plate if it sits too low.
Guess I was hoping to not have to drop the tank. How would you go about "poking a hole" in the tank, and what kind of fittings would you use?
I'd like to go the halfway expensive route. I bought the dual filler neck. I'd like to have a sub tank built (factory ones are hard to come by). I think a tank that's 12x8x30 will fit nicely and hold about 14 gallons give of take. I'd fill the sub tank and transfer to main tank with electric pump through the main tank vent line. I read a great post about a month ago with great step by step. Seemed like a good plan. Just need to get a tank built.
