I did an advanced SEARCH using keyword=4x4mods.com, "posts" only, all tech sections, and found 41 posts (including yours). Most were posts from members using these switches but I didn't read the posts. When searching the 80-Section, there were 4 posts.
I give up after reading 20 threads on "rocker switches". Also, I suck at searching. I can never find the right words to search for. Thanks for the help.
Picking the right words is becoming more difficult and is a LOT more difficult than it was 4 or 5 years ago because there are 10x the number of posts and threads.
Sometimes it is better to "bump" an older thread that covered your exact topic than to start a new one because most people use the CP function and find new posts to their subscribed threads and most of us have auto-subscribed to any thread they replied to.
I know, I already printed one for the in cab winch control using the antenna switch.
I have several projects that requires switches: Aux Batt, Aux Fan, Back up lights, etc.. and who knows what else for the future.
Also, I want them to be illuminated and have the ability to have a ON light indicator. On top of that some of them need to be on-off-on.
I have been doing a lot of research, and there is no real switch out there that can do all that and not screw up the wiring without some customization.
Also, I am looking for some organization. I think I can add several of these switches right behind the 4L shifter. That space there is kind of dead anyway.
I think I can accomplish my goal with these switches. I think I should be able to open up the switch and modify the internal lamps wiring to fit my needs, and also have cool, very well made symbols.
on-off-on rocker illuminated the best is the rear heater switch. Schematic easy to understand. Second best for simple off-on would be the rear defog switch due to the added activation light.
EDIT: personally I find the rockers found by the OP, plus the ARB switches, as just really ugly. So I am always looking for a way to keep the dash stock looking.
The problem with that is that I can't customize the lighting. For example that would be a problem with the Helroaring ON light indicator. This light has to be totally independent of the switch.
I had a similar issue with the ON indicator with the 115V Matrix switch. I had to really think about a solution.
Also the rear heater does not give me the ON indicator.
Last but not least, it is not easy to cut holes for the OEM switches. Basically you have to use what is available and I only have hole left. The aftermarket switches have "lips" that cover the cut out hole making it a nicer install. Therefore I can group them in the location that I want. I know you are going to suggest using the coin holder holes, but I don’t like that spot, as it is too easy to inadvertently activate the switch.
I know. I love the OEM look too, but I have to compromise in this case.
This outfit has been "unable to accept funds" by PayPal for some time. I have tried to order from them and even told them I would pick up the parts since they are in Bellingham, WA. No reply to my emails. Can't find those switches anywhere else on the net.
nakman here on 'Mud makes something that may work for you. It fits in the "cubby" above the radio and gives you 2 more horizontal switch locations. I saw these at CM09 and was very impressed. He also has several other products including a variety of mic holders and cup holders. Nice stuff actually.
Well this has got me thinking. I have a spare dash for my truck. I am thinking now instead of selling it to take it apart with a dremel and take the individual switch ports and figure out a way to attach those to a hole that is cut out, then the switch can just pop right in whereever I want it. I have been thinking about running the seat heater in the armrest on the door. Plus the whole center console is ripe for places to put switches.
I got all NAK's stuff last week and its pretty darn cool. The cupholder has been annoying and now that I have GOUCHO's cup holders I am think I don't need it any longer. The finish on the unit does need a little bit of touch up to get it looking more stock. Like just a few more coats of satin black would probably finish it off just fine.
I looked a those OTRATTW switches and they look good. What is even better is that I tracked down the manufacturer (http://www.carlingswitch.com/) , and they have a tool that you can actually configure the switch the way you want it. The options are endless !!!! it is so cool !
The problem is ordering them, and I am not sure how to do that.
For example, I configured this one:
Part Number: V6D2U66B-AACNF-17T
Description:
- White Fan symbol on negative. This means that the actual symbol is translucent and the rest is black. OEM look !!! and to get the green effect when lit I am sure I can take the switch apart and put some kind of green translucent plastic. - on-off-on: I want it this way so I can wire the top to shut down the system completely, middle will be Automatic mode, and down will me manual ON. - It has two lamps wired totally independent from the switch legs. I want this to wire the top lamp with the fan symbol with the OEM back light circuit(so I can see them at night), and the bottom “bar” light will be lit as ON indicator whenever the Fan kicks in.
This is exactly what I wanted to accomplish with the switch !!!! AWESOME
They have tons of documentation, and once you configure the switch you can even get a picture of what it will look like !!!
The pic below shows how the switch will look like and its internal wiring.
Part Number: V6D2U66B-AAC59-18B (similar guts as the one above) for back up lights
Description:
- Cool truck with light symbol on negative. They had other options but I liked this one with the little truck - on-off-on: Top position will disable the back up lights. Middle will be auto, meaning that they will turn on when I shift to reverse. Bottom position will be for manual ON. - It has two lamps wired totally independent from the switch legs. Top lamp will be wired to OEM dash circuit, and bottom “bar” will be lit for ON indication.
those look the same as arb switches. i've seen arb switches in an 80. don't know what it took to fit in, but they look kind of awkward. you might try to get pics of those that have used arb switches
Found these at west marine. No symbols, but are available with pilot lights in a variety of colors. They fit nicely in place of the dirt collecting coin holders.
