Aux meter wiring diagram
what kind of more data? dependent on your year and trim, you may be able to add a higher level trim data button (the four button assy right of the cluster). it gets est mpg, and trans temp along with ability to switch celsius to farenheit, iirc (i have a grade model, so all i got was ability to switch temp).
you can add a scangauge or ultragauge also. simple plug and play into the obdii port
I've got a 2011 Crewmax SR5. The data I can view is temp, avg mpg, instant mpg, range and I can switch between english and metric. What I'm wanting to do is find some way to also be able to view data like trans temp, water temp, oil press, volts, etc. I've thought about plug and play but really want to keep it stock looking and not rely on other viewing screens.
