I'm planning my wiring for my almost completed rack, it will have 4-55w lights on front, 2 separate relays and switches, and 14 or 16 gauge wire and 2-55w fog lights on back. I'm planning on adding a separate block underhood for these connections to the battery. I figured my draw to be 27.5 amps. Should the fuse on the lead to the battery be 30amp? If so do most people put a larger fuse in to start, or upgrade as additional equipment is added to the aux block? And the same for the wire from the battery to the block, according to the charts i've seen 14 or 16 gauge would be enough also? My goal is for it to look as good as many of the post i found while searching what others have done.
