My JDM has that aux cooling fan on the RHD side in front of the condenser. It is controlled by the AC switch. However, when I look at the rig upfront, I feel that the overall "design/look" effect is not symmetic. The LHD side looks blank - with just the stock horns in them.
Am thinking of adding another aux fan on the left side to balance the look and fill up the empty space on the LH side. And in return for the "balanced look effect", I can get more cooler air into the engine bay.
Questions before I purchase one from a local shop here:
- can I just do a parallel wire tap to the wiring of the existing aux fan? Or should I have a separate wiring (complete with fuse/relay, switch, etc.)?
- the extra cool air that would be generated is ok for the engine, right? More air, the cooler the engine bay becomes and hence good for the engine, right? I ran this idea to somebody and he said that another aux fan is not needed since the condenser needs "to get hot" as well.
inputs? ok to add 1 more aux fan?
