Automatic trans in a BJ60?
Portland OR - USA
Im contemplating an automatic trans behind a 3B(with turbo) or 13BT in a 60 series.
Is this a good idea?
I know some of the JDM 7x series that have made it to Canada have autos, but I havent read a lot about whether or not people like the setup. I also have never seen an auto/4cyl swapped into a 60. Considering the 2H came with an auto (the same trans?) I dont see why there should be any issues.
Any drivetrain related issues to consider with this setup in a 60? Would I need to consider different axle gearing than I would with a manual trans?
Thanks
The trans may be the same but the input shafts will be different between the 2H and the 3B so I think you will have a hard time finding a A440 (I think thats the trans??) with a 3B input shaft.
Sorry, I wasnt really looking for info on how to connect the two. Maybe that wasnt clear in what I posted.
The 13BT already comes connected to an auto trans in some of the JDM rigs. I was pointing out that this setup probably uses the same trans as the 2H combo so it should be OK in a 60.
PM Lumpy70. He has a low mileage a440 out of his BJ74 that's for sale. You'll get the flex plate and linkages that way and its sure to bolt up. I'm sure he'll even toss in the shifter though you're probably better off getting one from a FJ62.
lynchmob,
I got your question and I think yes, it is a go. (see my final note below) There's a point where all the trucks are common: When you can't unbolt anything more from the thing! That's the point you may want to assume you will need to start from.
If it was my project, I'd be sure to collect the trans cross member, mounts, driveshafts, linkages, cables, wiring harness, boots and shifter. Oh, and cooler lines, radiator and dipstick.
Be sure to get a non-electrically controlled trans. Might be easier!
Note: It would be advisable to perform a tranny swap form a 60 series donor, to reduce the complications of an inter series swap.
Rick
I think if you connect a jdm auto to a 3b it would be a slug even more so in the 60. A turbo'd 13b-t should be close to a 2h in power. They had auto's. So it should be ok.
For rear diffs the auto's seem to get 4.11 gears, while the manuals got 3.70....
Thanks
I was thinking 4.1 at least. Considering the FJ62 with an auto had 4.1 vs the FJ60 I would guess that is in part due to the Auto trans.
So with 33's or 35's , 13BT and an auto trans I might even want 4.56.
Thanks
In the 70 series section there is guys running 13b-t auto's with bigger tires. Scope them out and see what they recommend.
You won't want the 13b-t screaming.
