Auto trans not staying in first
Everett, WA
Howdy y'all, I'm having a problem in which when in 4low and L, it acts like it's actually in 2. It may start in 1st from a stop but it won't stay in 1st - making steep inclines and declines a bit difficult.
Everything else with the trans is great and fresh fluid at the correct level. Should I look into kickdown cable? Shift lever? I'm on trails so can't tear it apart too much.
91 hdj81 "a442" but it's all hydraulic so basically a440
What does the gear indicator on the dash do when it is jumping around? Will it shift down into first with appropriate load/throttle? Or just never goes into first?
I'm manually putting it in L - indicator stays in L the whole time, including when it upshifts itself to 2. Upshifting manually to 2 - indicates 2 but no shift change since it already shifted itself to 2. Holds 2 and 3 fine, just need it to hold L!
I’d inspect the linkage situation and if it seems to be properly adjusted it sounds like it might be an issue with the trans itself (valve body?)
