Auto-Trans Fluid Change Options
Arizona
Website
www.behance.net
How-dee
I have a 2008 FJC, automatic.
About 325,000 miles.
A while back, at around 230,000 miles, I started getting a vibration at about 20-25mph and it would go away once I hit 30.
I did some looking and I think someone here adviised changing some of the trans fluid, but not doing a flush.
I changed the filter and replaced the fluid that came out with the same amount of new fluid.
The vibration stopped.
Then I did another fluid drain at the next oil change. No more issues.
However, I want to keep doing this: maybe drain/replace a quart or two every oil change.
Of course this transmission has neither no way to check the fluid.
Also, the fill plug on the side is seized. A mechanic tried gently tapping with a hammer, a little heat, and nothing. He stopped and said he was afraid of forcing it and busting it.
I installed a transmission cooler a while back. It's located at the front at the grill.
Is there anyone who's installed some kind of refill valve for the auto transmission?
I am thinking something on the low pressure side of the cooler side up at the grill.
I could undo the line and use a syringe type thing to replace the exact amount I drain out, but maybe installing an inline refill valve or something would be better.
I would rather not reinvent the wheel so...
Ideas welcome.
Thanks!
Having thought of it a bit more, I think it would be much better to use the overflow port hole with an adapter to refill as well as drain. I have seen something like that for the oil pan, but not the transmission pan.
You could just get a better different mechanic to get the fill port open.....weld a nut to it or the like.
I guess so long as you can do the check procedure (that is what the overflow port is for), then getting the fluid in there by whatever means is alright, just a pain. I do suppose you could find a similar threaded barbed fitting and just syringe/pump the fluid up through the check plug.
The mechanic has been a good one. My worry is they bust it and then have to weld it, or worse-something catastrophic happens, and now a fluid change turns into $6,000.
I was thinking that: what you said: a barbed fitting and the syringe, which I have.
What would be great would be an adapter permanently installed into the drain port that would let me drain and refill, but that would also mean something sticking out that would catch on a rock.
Maybe a skid plate there would solve that.
Something like this:
I dont know if you are willing to try it yourself, and understand the hesitancy to muck it up, but I've been there with other drain plugs.
One of these sockets can do wonders. If you dremel a slice through the middle of the plug that is wide enough to fit one row of these little socket 'pins', they will drop into the groove and act as a huge flathead screwdriver and usually get it undone.
I think he just needs to take a 6-sided socket and grind the crown off so it sits tightly against the plug head. And use a bigger breaker bar. I don't think you are going to crack the case before the plug lets loose.
Thanks for the suggestions. I may try one of those later. For now, I am not taking the risk.
I ordered the adapter to let me drain and fill from the drain plug, and a skid plate so that hopefully it will protect the adapter. Will have to cut an access hole in the aluminum skidplate, and maybe put a screw-on cover for that hole, but it should be good.
I'll post how it turns out once I get it and install.
