Auto tranny service.
Craig, Co.
What's happening. Brand new to the forum and looking for some help. I just bought a 1997 Lexus LX 450 with 107,000 miles. I wanted to change the tranny fluid and have gotten some conflicting stories. From what I have read in my owners manual there is no replaceable filter and you wouldn't have it flushed by a shop. Do you just drain the fluid and replace it with fresh? I'm new to the whole automatic tranny thing!
Thanks,
Travis
tranny flush
You might try the search for transmission fluid exchange. There's a nice write-up on it for your 80 series. However, this is a quick response on how I did it. Drain and measure fluid. Refill with the same amount. I believe I drained 6 qts. Now unhook the top line to the Transmission cooler and replace with about 6 to 8 feet of 3/8" hose. Put the hose in a clear gallon milk jug and start the engine. The fluid will pump into the jug, turn off the engine when the jug is about 90% full. This can be done in the seat of your truck with the longer hose. Now refill with the same amount (4 qts.). Repeat about 3 to 4 times until the fluid looks new. Disconnect your bypass hose. Connect back the cooler hose. Takes about 20 qts and 30 minutes as I recall. Easy job and yes no need to change the filter (It's a metal screen).
I just bought my 94 Locked LC on monday and changed the oil and tranny fluid yesterday. My first attempt I just put the drain hose into the oil drain pan but quicky relized I could not monitor the amount accurately:doh:. So I used one of the oil gallon containers I bought which have quart level and did about 10 quarts or so since thats all I had at the house. One quick thing is to be sure you drian the pan before anything else to get that old fluid out of the system before you start. Then over fill it by 2 quarts or so this way you can stop at 4 quarts and still have fluid in the pan without it running dry.
