Auto tranny issue
!993 US spec Cruiser with about 210,000 miles. When I back up fast, like say you came to a deadend so you pop it in reverse and quickly reverse, my car slips out of gear. As you slow it will abruptly drop back in gear. This sounds expensive to me. The fluid is full(Mobil 1 Syn) and it smells fine and is still red. It is, however, due to be changed. Anyone experienced this before? Suggestions?
Suggestion: stay out the bad neighborhoods forcing you to throw your truck in reverse quickly and stomp the gas to get the he!! out ;) :lol:
Sorry couldnt resist, but I dont have any ideas. sorry.
Common stuff. Nothing to worry though.
1. An auto tranny is a hydraulic device, so when you put the lever in R it doesn't mean it is in R already (as with manual trans). Instead fluid starts flowing and closes/opens/whatever some valves to put the tranny in R. Every time you switch from D to R you should wait a second or more to let the tranny complete the shift.
2. Another cause might be a factory defect. Some trannies have a spring which is too soft and some wrong washers (not important right now) which make it slip in reverse. Toyota used to upgrade these trannies for free (search 'transmission tsb' or similar). Just be easy on the pedal when reversing and forget about the problem. It is also safer not to reverse like a moron as you can't see much and small kids are everywhere.
Check the wiring harness at the back of the engine next to the EGR pipe.
If you have the Factory Service manual, in it is a trouble shooting chart you cn run through as well.
