Auto lock question
Johnson City, TN
1997 LX 450
148k
Non-working, or not still installed, factory alarm (I bought the truck this way)
When I try to unlock all the doors via turning the key in the driver's door 2x, about 3/4 of the time my rear driver's side door does not unlock. I have found on a few occasions that when I lock the doors via the inside door lock switch that the rear driver's side door does not lock - happens MUCH less frequently than the unlock problem. All the other doors lock and unlock without problem. I know it seems trivial, and on the grand scheme of things that I still need to do to my truck it is, but it is frustrating to have both arms full with my cup of java in hand each morning to fight with the locks. Any ideas on where I need to start in looking at this issue?
On a side note, my driver's switch will roll the passenger (front) window down, but will not roll it up - any input is appreciated.
Best,
Katie
The 100's have motors in the door locks, the brushes wear out and stop working, 80,s may do as well. They are expensive via Toyota, but you can muck around and replace the motor, available ebay. Do a search and all will be revealed, I'm sure someone has had the same trouble.
My guess for the window is the switch itself, it just reverses the wires to power the motor in the opposite direction.
