Auto down stuck?
Spokane, Wa.
I just burnt up my window motor. After testing I discovered via my test light that if you push the drivers window to auto down, it doesn't ever stop, said another way it sends power to the motor to roll down constantly.
Thoughts other than buying a new switch?
Other than?
No.
SwitchDoctor.com for $45
I'm pretty sure that the stop circuit for the auto-down function senses the load on the window motor - i.e. the window reaches the bottom, motor stalls, and the circuit senses that extra load and cuts power.
It sounds to me like the motor is bad rather than the switch. I'd disconnect everything and test the motor independent of vehicle wiring and switches.
You should certainly test the motor before throwing money at another switch.
Motor was brand new and working fine. It isn't anymore lol.
New motor and switch on the way, just wanted to see if anyone had a fix first!
FYI, the switch doctor window switch was only $25 at Amazon.
