Good Morning Everone - Does any one know how I can get my hands on one of the tire swings we see on all the Aussie 80 series rigs up here in the states? Like this one....
I have seen one of these mounted on a US truck They dont do well as the supports under the sheet metal are not there . The one I saw the mounts were doing some really bad things to the rear corner panel . To do it right you really need to do some big time beefing up the corner to keep it on and ripping up the fender .
For the work it may not be worth it but it comes down to what want
Does anyone have a photo of the inside mounts of the beefed up corner? or what ever the factory did to re-enforce the corner? Is it a welded in part, or a factory bolt in bracket of some sort?
Here is one, but as others have said you would be much better off getting a stronger bumper and carrier.
http://www.cruiserparts.net/shop/index.php?main_page=product_info&cPath=6_43&products_id=297
Without a tire mounted to the carrier I can see that this mount does not support the weight of the spare by resting on a mount of some sort attached to the top of the bumper. I though that's where it clicked in; not to a mount on the sheetmetal of the tail gate.
Guess I gotta pony-up for the real deal. I appreciate everyones input.
Those factory wheel carriers aren't that common in Australia, they are usually found on the imported Saharas.
Heres a company in Aust that makes a decent swing away that fits the standard bar,
http://www.oppositelock.com.au/rede...ctDetails.aspx?deptID=7&catID=7&itemID=SWC80L
Struddy
