Aussie Locker install, semi vs full float
there is definitely a groove for the c-clip to go in. once that is lined up on both sides it should drop right in almost too easily. before you put the c-clip in you push the right side space to the left using the coat hanger tool in the groove for the c-clip. once the c-clip is in all the way, rotate the axle so the groove is facing up, otherwise the c-clip can work its way out a little and you will have a hard time getting the spacer seated back to the left and will not be able to get the pin back in.
Bhmmapping, giving it a shot again today. Got cold and dark last night so we decided to stop before we started trying to force things into position and end up screwing something up. I see the groove you are talking about now.
Also, the spacer was pushed to the left all the way before the picture was taken. It just slipped back over there when we let everything go to get the camera.
Yup, once apart in daylight the groove became quite obvious. Made all the difference. We got it R&R'd in about an hour and just buttoned it up. All seems good except the t'case shifter is extremely hard to select hi/low (while still on stands). any thoughts???
Check the fluid? You didn't do anything to affect t-case shifting other than letting it sit on jack stands....so probably fluid or shifter issue not related to the locker install.
Alex, you're a little behind on that locker but let me tell you....it's damn great!
that's because i was stubborn and hell bound on putting in selectable ARB's. But then realizing that i really needed gears as well, oh, and air supply, i just said this will do for the time being and let me have some real fun.
On the shifter thing J, i'm sure you put the transmission in N and applied the brake before trying to shift, right?
Yes Yes, shifter was in Neutral. Just went for some lunch and think things just needed to move around. Its all A ok right now. Aussie said an 85/140 weight will help the initial ratcheting. Also said you could hit the trails ASAP :bounce:
Yep, INSTANT satisfaction. Oh yea, I forgot I was also one up on you with gears! But you got that snazzy ARB hanging off the front of your rig....
I continue to use the thicker stuff even after that 500mi break-in period, keeps the louder bangs and pops at bay.
Just got back in from playin' around a little bit, theres a little place just above my house thats nothing major just one pretty good bank to climb and a bunch of the nasty stuff. The Aussie made a big difference. The initial noises were a little louder than anticipated, and were louder than Alex's but were barely noticable on the way home and that was with me listening for them. The install went easily today after noticing the notch for the c-clip to slide in(I AM AN IDIOT by the way). Big thanks to J and Alex for their help and patience. Going wheelin' this weekend so I should really be able to give her a good test:steer:
