Aussie Locker Install in a 91 need help!!
Fairfax, VA
Ok, so last year I got a Aussie for Xmas. I ran it for a short time and was having issues. I am gonna try and reinstall tommorow to check my specs again since I cant remember what they were. Well since my truck is a 91 with c-clips there wasnt a exact installation guide. I used Hayes thread, which was awesome. But I have some questions. I have attached 2 photos from his thread. I have a question about the first pic. When you take the measurement between the centerpin and axle gears, what is the spec? And do you have to use 2 feeler gauges and measure at the same time? The other pic show the final measurement between the cam gears. I dont have that spec either. This question might seem stupid, but on Aussies site, it talks about c-clip axels needing to remove the thrust washers. Is this true for the 91? Any one who has done a Aussie install on a 91-92 please chime in.
Thanks
want issues were you haveing
Kind of hard to explain, but I will post my original thread from a year ago. Needless to say, Aussie thought it was my trans, I felt it was the locker or I wass off on my specs on installation. Obviously it was not my trans because I have put about 10k miles on it since I removed the locker.
https://forum.ih8mud.com/80-series-tech/262229-trans-aussie-locker-problem.html
P.S I am not bashing Aussie at all, this just got put on the backburner for me and I recently just started wanting to figure this all out.
Cool thanks for quick reply, Im gonna use yours, Haynes and ZUK's site for reference in the morning.
:cheers:
Update
I reinstalled Aussier in the rear. All measurements fell within Aussie spec. This time I didnt use any grease to old pieces in place while putting together, which made it a pain. So far so good. Only driven about 5 miles with no issues. It seem alot quieter than before. Well I will update in a couple hundred miles to see if everything is cool.
This is pretty cool, I want to take a ride in this if you are making it out to the obx trip in April.
Good job getting it to work! I will be getting an Aussie when I have the cash. What was the issue, IYO? Was it just a matter of not using the grease to reassemble that made the difference?
When in April is the OBX trip? Id totally cruise down there.
