Howdy everyone. First post here, been lurking around for the last couple months, bought my 100 series back in July but now that the weather is cooling down here on the surface of the sun (Arizona) I am finally starting to work on some of the issues with my first ever LC.
I am getting the dreaded "Audio Off" message on my LX470.
It's a 2001 with the Nav system (see picture). I've looked through several threads regarding the topic and it seems there is no definitive answer on this.
Mine seems unique to a lot of the other threads I've read, in that all of the buttons circled in green work, and make beeps when you press them, however, all the buttons in red do nothing at all.
Is what is strange, is my radio used to work just fine when I first bought the car. Recently, one morning when I started it, it popped up with the Audio Off message, and it has been like that ever since (3-4 weeks)
My antenna also used to raise and lower with the switch on the dash, it no longer does anything at all.
Things I've done:
- Checked all fuses (all are good)
- Gone into the on screen diagnostics menu and done the button switch test - all the buttons in green work in the switch test, the ones in red don't register or make beeps, but I'm not sure if that menu detects them normally or not.
Anyone have any pointers? Should I remove the radio portion and check connections behind the unit?
Things I've done:
