Attaching roll bar???
Interested in opinions from the experts on how to best attach this roll bar.
Should I center it over the wheel well or move it towards the front to make use of the hole that is already there?
Should I cut the brace between between the front and back poles so that it will sit down between the raised ridges on the wheel well?
Or just attach it as it is now so that it rides on top of the ridges?
I can't afford a different roll bar and this 40 will only be used for short trips around town - no wheeling, no significant speed - purpose primarily to make me feel a little better about the family along for rides, to attach a bimini top, and to attach the jump seats. Thank you.
William
on sor.com there is a diagram that shows that to fit a certain top on there you need it 42 3/4" from the rib on the windshield frame to the center of the roll bar. i don't know if that is what you want to know, but i would say that is a pretty good spot to mount it
here's the diagram
Specter Off-Road-Land Cruiser Parts - Page 272-Bikini & Summer Tops
its about 3/4 the way down the page
I would not delude yourself into thinking that is going to protect you or your family. It looks like your truck did not come with a roll bar from the factory and is probably missing the roll bar tub supports also. If you actually want to make the truck safer for you and your family invest in a real cage or keep the hardtop on. Just my .02
what you have looks to be a Smittybuilt bar.
not a bad bar and the tube is "thicker" than stock.
i would move it forward about 6" or so.
i personally would use a plate at each side under the wheelwell that is larger than the plate the bar is welded to.
doing this eliminate the "shear" effect in case of a roll.
Shearing: when two plates equal in size, sandwich sheet metal, the plates act like a shear when force is applied.
hence cutting/shearing right thru the sheet metal.
do this with the bar you have and it will be better than no bar at all.
Thank you all for your advice! So the roll bar sits on the ridges on top of the wheel well leaving a small gap under the plate? Will these ridges compress when you tighten up the bolts attaching the top plate to the wheel well?
Again, thanks for walking me through this.
I had that same bar in my rig. Mine had angle brackets that bolted to the brackets on the bar and into threaded holes inside the tub rail. (In addition to the bolts that attached to the wheel wells.)
