My 2001 Lexus LX470 ATRAC light is always on, how can i turn it off?
forum.ih8mud.com
Break the bulbMy 2001 Lexus LX470 ATRAC light is always on, how can i turn it off?
Thanks BroIt’s possible one or more of your speed sensors or it’s wiring is faulty/damaged. Or could be as simple as dirty/no contact. Next area to check is the ABS, since atrac is parallel with it.
How To: Wheel Speed Sensor Replacement
I just had to do this procedure on my 2006 after the VSC, ABS, and TRAC lights went off. I had my mechanic check the codes and the right front sensor registered an error. You can check the Ohm's for the sensor, apparently they should read around 1.0, in my case, nothing, so new sensor it was...forum.ih8mud.com
