ATF Oil Cooler Question
Orangevale, CA
I was wondering if anyone can tell by looking at the pic at the bottom of the radiator ATF oil cooler which lines are incoming to the cooler and which is outgoing?
What I would like to do is plumb in a Motorguard MG-30 ATF bypass filter. Anyone know for certain the difference between these two fittings? Many thanks in advance.
mine used to enter left and exit on the right, but i dont think it matters, its just a POS brass tube that can in some cases fracture and leak.
I've bypassed mine.
Does it not have a cooler on the front left hand side?
That's correct. That would be the auxilliary ATF cooler. However, I'm referring to the heat exchanger in the bottom of the radiator pictured above which also cools/warms the ATF.
With regard to plumbing the Motorguard filter, it could be mounted to whatever fitting I choose and should work fine either way, but I have a preference to mounting the filter so that the ATF is hottest as it enters the filter housing so that I can determine by 'touch' or 'feel' if there is ATF flowing through the filter medium.
