ATF 4X - Transmission Flush
Monterey, CA
Don't flame on me, I did my search found this thread.
https://forum.ih8mud.com/showthread.php?t=19299&highlight=atf+flush
But, I was thinking of doing what I did to my Acura with 4X flush, and I am going to try this to my LC. What do you guys think? Got this from www.acura-legend.com
Of course, replace all “Honda ATF” with “Toyota ATF” or “Mobile 1 ATF”, and quantity is different.
Total stuff needed:
(1) Bottle of smart blend ( Black Bottle)
(I used Lube Guard from NAPA for $11.00)
(4) quarts of "F" type Trans fluid
(7) quarts of Dextron fluid
(4) quarts of Genuine Honda fluid
Time to play with your car.......
1. Drain the fluid and add 3.5 quarts of "F" type fluid. F-fluid (ATF) is what is used in Ford
transmissions. It has a very high detergent base to it that is designed to clean the internal parts and to break down varnish build up.
2. Drive the
car around for several miles and then drain it again . I do not recommend that you leave the F-type fluid in the car for an
extended time.
3. Now having drained the fluid refill the unit with 3.5 qt's of
Dextron II or III and again drive the car around for a few miles
working the Dextron in. While you are doing this what you are
actually doing is diluting the F-type fluid and flushing the dirty fluid
out of the converter at the same time.
4. Return to the driveway and dump the fluid again and
5. repeat the process again. (Steps 3-4)
6. Now , having returned once again , you have drained one last time. At this point what little F-type fluid that was left has been drastically diluted and the majority of what you have left is Dextron.
7. Now fill the tranny up with Genuine
Honda ATF . Honda fluid has a high silicone base to it and that is what will keep your tranny shifting smooth. You now have 3.5 quarts of Honda fluid mixed in with about 5qts of Dextron mixed with .5 qts of F type fluid (Mix) .
Not enough to hurt a thing. Now to even things out and bring us all
back to Basic Honda fluid , get a bottle of a product called "Smart
Blend" It's made by a company called "Life Products" Be sure to
get the Black bottle as it is specially designed to convert Dextron
over to Honda fluid, this is a product that we endorse, and use it in
all our transmissions through out the building process. If you can't
find it then try Lube Guard , and again use the Black bottle. Both
products have red bottles and I thin also a Blue one too?
8. Pour one full bottle of Smart Blend into the tranny and you're set. Smart blend reduces operating temps as well as is a friction modifier that will reduce clutch pack chatter as well as help with converter lock up. Now the reason you start with the F type fluid is to clean . Then you use Dextron to dilute the F-type (
Ford) and besides to dump that much Honda fluid just to flush would be a sin, not to mention costly as all get up.
Ting- sounds like the sort of "witch's brew" random mixtures you see on BITOG (Bob is the Oil Guy) that makes OCD, anal-retentive car-nuts feel like they are doing something better for their car simply because they are doing something "different".
Landcruiser trannies are pretty bulletproof. Just use the recommended fluid type and change on a regular basis. From what I've seen, all the "Lube Guard" and "super special black bottle lube" additives only hurt. If you really want to do something *good* for your tranny, forget all that baloney (which sounds like it was aimed specifically at Honda trannies anyway). Just drop the pan, clean screen/pan, and perform tranny fluid exchange with Mobil 1 Synthetic ATF or equivalent every 30K (some use a 60K interval for fluid exchange, but do a drain/fill at 15k). Your tranny will likely make it well beyond 300K mi. using this service routine, as evidenced by several we've seen on the board and off- some with less stringent tranny maintenance than I mentioned. When you have such a sure thing with normal maintenance, why risk shorter tranny life by playing home-chemist??
Thanks! I must admit that Honda tranny suck big time! I don't even notice shift changes in my LX. Smooth like butter....
Do I need to change the screen?
I've owned Acura Legends since they came out in 1986 up to a 1995 at present. Additionally, I've had a couple of LC's, presently a 1995.
LC's trans don't have the vulnerability that the Legends do so the standard drain / fill process works ok. Hondas are finicky about Honda trans fluids as well.
BTW, my Legend has a nice smooth shifting tranny with 126K
For laughs, read the HG threads hear and on the Acura forums.
nope- you can keep using the same one, unlike a filter- just clean it off every 30k or so.
