Assorted queries
Cairns, Far North Queensland
I was wondering if anybody could shed some light on the following regarding 2F FJ40 ?
  1. Where is the water temperature sender located? - gauge has stopped working.
  2. What is the torque setting for the pushrod cover bolts - i have just pinched them on so far.
  3. What is the dwell angle for the stock dizzy - mine is curently showing 36deg.
  4. I have an aftermarket tacho that worked until recently - it now gives strange readings - i.e is at 7000rpm when switched off, but flickers downwards when the motor fires - all connections look good and the unit is switched to 6 cyl.
I have had a lot of helpful advice regarding the replacement of the front plate gasket on my FJ40 and the job is now done and appears good - thanks guys.
BTW - do people generally set their carbs up using a CO gauge or by ear? and what are the benefits of the CO gauge?
