Asco Hubs?
Madison, NC
Just went out wheelin and just about got stuck because my hubs didnt lock in, I searched the FAQ's and found a few things that it might be, my question is my hubs say ASCO, are these Aisin hubs?. The driver side has some runny grease coming out from it. I just got my 40 about a month ago and when I first got it the hubs didnt lock, so I took the front cover off cleaned them and put them back on and they seemed to work, then I noticed the runny grease and now there not working again. If anyone has any advice on this problem it would be appreciated, and if anyone can tell me if these are Aisin hubs. Thanks a bunch.
yes they are the same.
The grease is probably the inner axle seal leaking mixing with grease and coming out. sounds like you need a front axle overhaul. It's easy enough it just takes time.
Thanks a bunch i'll check it out, hopefully its not to big of a job.
if the only thing that is bad is the inner axle seal then you'll have to remove the hubs, brake stuffs, spindle and then line the flat spots of the birf with the knuckle and remove. Use the tool to pull the old seal, clean, install new seal. After that is done insert the birfs/inner axle combos and fill fluids accordingly.
