Are my Shocks causing problems?
Beaumont, Texas
Website
www.marklowimagery.com
I have Slee's 4" lift with everything except for my shocks. I had purchased a full set of the OME LTR's just before I did my lift from 2.5 to 4" so I already installed them and mounted the remote reservoir's so I decided to run them despite the fact that they are not long enough.
I noticed just the other day driving through a parking lot, when I go over a speed bump just fast enough to make the truck jump up and then drop on the other side. I hear a banging noise and I am not sure exactly what it is. I guess the front axle is doing a full drop mid air briefly and it "sounds" like the springs are unseating momentarily but I don't think that is what it is. I lifted the truck high enough to support it on the frame rails and let the axle drop without touching the tires down, and went around with a dead blow and regular rubber mallet and found that on the lower shock mounts, the bottom bushing was very compressed and the top one was loose and the washer would ring as I tapped the control arm. On the upper shock mount, the top bushing was fully compressed and the bottom one was loose as well. Are the shocks actually bottoming out at full drop? I lowered the truck back down on the groung and tightened the shock mounts a few more turns and tested it again and those same bushings were still somewhat loose and the washers spin easily but they did tighten up a little more..
I think the same thing would be happening even if I had the longer OME L Nitros but wouldn't they also hold or limit the axle at full drop, loosening the unloaded bushings? If this is not the banging noise I am hearing then I don't know what else it could be and I have checked all fasteners for correct tourque. It almost sounds like the back does when I go over the same speed bump but with the trailer hitch installed into my Kaymar bumper. It fits in there but with some slack and it will rattle but by removing it, everything is tight. Does anyone know what else I might check in the front???
In a normal solid axle suspension, the shocks stop things at full droop so this seems normal procedure. From your description it sounds like the shocks are controlling the limit of full droop and I'd expect that even with different shocks and springs as long as they're matched and intended for installation together.
What bothers me is the slack in the bushings. Anytime the suspension reverses direction, you're going to get that movement and it sounds like a bushing might be already letting metal on metal contact occur from the beating. I think you should tighten the mounts such that the upper and lower bushings are tightened against each other so there's no slack. I'm assuming you can merely thread the upper nut down more to pull the shock tighter. Disregard this advice if there's no more tightening adjustment left and the bushings are hammered so bad they will need to be replaced to have enough stack height to tighten against each other.
DougM
are your LTR's the same length as the N74 (whatever the OME Heavy shocks are)?
If so you are bottoming out the shock for sure . I only had 1" of extension left on the OME w/ Slee4 lift.
Well I have tightened the shock mounts almost maxed but there might be a little more adjustment left. I used the impact on the bottoms just to make it easier to hold keep the shock piston rod from turning and I did the tops while holding the shocks outer housing. I might be able to stack on another OME washer on each mount to give more tightening room. I might try to make a measurement top to bottom while the truck is on the ground, then measure again while the axle is at full droop, and then remove the bottom mount and compress the shock fully and measure again. I am not sure how much up and down travel is required but I know the shocks aren't matched with the springs. As I recall, when I replaced my last set on OME Nitro's , non L, I measured the LTR's to them and they were the same at full extension and compression. It just depends on where the shock sits on the Slee 4" springs at rest. Wouldn't it be more likely that I would bottom out the shock at full extension and not as likely to bottom out at full compression where the bump stops contact, since the resting height has the shocks extended past the mid point of full range? I know the LTR's are not matched with my springs but I figured I could still run them as long as I am not doing any hard core wheeling. Also, when letting the axle droop fully with the jack stands, the springs are not loose or at least I can't move them and they don't rattle with the mallet bumping test so they have not unloaded.
Have you run the truck over a bump since tightening the shocks? That was my guess, that the shocks were loose, and I agree that the shocks are usually the droop stop on most setups, so that shouldn't be a problem. Compressing them too far can cause damage, but that doesn't sound like your problem.
-Spike
Yes the LTR's measured the same as the OME N74 Nitro Chargers so if one inch of up travel is all that is left then that may very well be the problem. And yes the noise is still there after my initial tightening but I might be able to get a little more but the bushings will be compressed quite a bit leaving less room for them to actually help with dampening. I am just probably going to get a set of the OME L's and see if that cures the problem. Now I remember this unloaded axle thumping when comming out of a mud hole at a normal pace. When the front came up and sort of bounced high enough to allow the axle to drop fully. I felt the thump and wondered about it since then. I just feel that everything should be tight and controlled in the suspension especially in these easy situations. If not then something must be loose and will fail at some point.
Imagery,
You're not getting this. Forget about whether the shocks are bottoming or topping. That's an issue, yes, but it's minor compared to what's going on over every bump. Each and every time the suspension changes direction (from up to down or vice versa) the loose bushings let the shock move up or down and jackhammer the bushings whether you hear them or not. See, the suspension wants to move instantly due to the enormous pressure of the springs wanting to instantly extend, or the ground wanting the tire to instantly come up and compress the springs. But the shocks prevent that by resisting the movement. If the shock is not solidly mounted, then it cannot stop the suspension movement in either direction until it slides enough to be stopped by using up the slack in the bushing, THEN the shock compression begins.
So even though things seem tight at full droop, you've still got a problem. At full droop, the springs are merely pulling the upper bushings down tightly and you're interpreting that wrongly as everything's OK. The shock is topped out and the upper bushings seem tight. If you could somehow push up fast and hard, you'd see the shock slam against the lower bushings as it physically moved up until the slack was taken up. But you can't without some elaborate setup. Trust me, that is what is happening if your upper bushings and lower bushings are not in tension against each other as they should be.
DougM
How many washer do you have installed and what is the order? In the old days (and LTR shocks might be packed the same since they do not sell that much) there were two indexing washers (the ones with the lip) If you installed both, they would bottom out against each other and the shock would be loose on the metal mounting plate, even though the nut is tight.
Also make sure that you do not bottom out the nut. If the above is true, remove one index washer and install it under the nut (or even another washer if needed). Then tighten and see what happens.
Here are images of my washer placement. Am I supposed to have another washer, centering or plain between the top bushing and the mounting surface?
I guess I was not exactly sure of how they should be and this is how I always arranged them.
I see what you are saying Doug and that is exactly what is going on. Have a look at my washer placement and number used and tell me what I should do.
Looks like your bushings don't "budge" enough - I'd tighten up the nuts some more.
I had the same tapping sound going over speed bumps as the shocks bounce and re-bounce. Tightened up the nuts and that fixed it on mine.
I'll try to tighten them up some more but I am wondering if I need a washer on both contact surfaces of the mount tabs. I think I have it just like the illustration on in the instructions that came with the shocks.
I'm with Christo. You need what is referred to as more "stack height" to compress against. I think Christo is dead on as to what's happening. Don't tighten any more-you're going to strip threads. You need more washers.
DougM
Alright, I will add one more washer under each nut and retighten. As it is now, I really felt like I was running out of threads so couldn't tighten them any more. I'll do that and then test it again and let you know the results. I am also going to take one of my old Nitros and measure full compression and extension since they are the same as the LTS's and then measure the LTR's length as it sits now on the 4" springs. I was thinking about going up to the 6" springs so I imaging for sure I will have to go to a longer shock.
DougM
From what I remember, the threaded stems (on the front shocks) are more than 1" long; so I was assuming that there are more room to tighten things up first. The advantage is that, should you stripped the inner part of the stem, you could always add more washers - stripping the outer part on the other hand...;)
I added a washer under each nut and was able to get the bushings to compress more but have not tested them on the bumps. I measured the front shocks, mount to mount and resting on the springs, they are 25 3/4" and when I lifted the frame to full drop, they measured 26 3/4". That is only 1" of down travel that the shocks allow which can't be right. I think there is a thread somewhere that talks about installing some type of extensions to the top mounts to compress the shocks more towards their center travel whild the truck is at rest. Is that something I should look into if I decide to keep these LTR's of shoule I just go ahead and replace them? Has anyone got the measurements like I did to see how much down travel the Nitro73L's allow?
I made some top mount extensions, about 3" more compression at static ride height and it did fix the problem with the overextension banging. It is very smooth as it should be and just the normal ride on the road feels better as well. I am going to make some better more permanent extensions out of 1/4" hard rolled steel 2" box. Not sure exactly how I will end up making it but will figure it out as I work. Will post my progress.
Mark
