Are my OME spring installed on the wrong side ---regarding "lean and roll"?
sleeoffroad said:
Allen, I would suggest you try to locate someone close to your with OME outfitted truck and drive it to compare. We have never sold OME to someone and had them complain about excessive body roll. In fact that is one of the best things of OME is that it improves over stock. So either something is wrong, or a part has failed.
What are you comparing it to. Also did this start suddenly?
Oh, and just to be sure, you are saying that you have to much body roll wouhen cornering. More than you had with stock suspension?
Please answer the questions. The answers will be very telling.
Kalawang
Allen, are the springs all properly seated in their bases? Go to www.sleeoffroad.com to the tech section and then to the write up on the OME install. There is a photo or two there showing how the bottom end of the springs lines up to a stop in the base. Compare this to your springs.
Poorly seated springs would only add noise. I'm pretty sure it does nothing more than make the owner feel bad and possibly make the passengers worry.
Kalawang
