Are all Motor mount brackets the same?
Great Barrington, MA
I’ve got a ‘75 fj40 with a blown SBC and I’ve got a good ‘75 drivetrain missing all the motor mount brackets. I was wondering if motor mount brackets from a 1970 fj40 would work.. and also the frame brackets off of the frame. Especially the rear brackets that are bolted to the bellhousing. Thanks
I used ‘74 brackets when I put an later model 2F in. The bolts on the 2F are larger, so you’ll have to drill the holes out accordingly.
Yep, I do have all the weld-on frame brackets (Downey Off Road left overs). What I want is the engine block bolt-on brackets, and the transfer-case rear propeller mount if you have that, not at all interested in bellhousing motor mounts.
