ARB switch problem?
Hi Lads,
I just finished a ARB front locker install in my cruiser and I'm not sure if the locker switch is working correctly. When I turn on the compressor switch it lights up and the compressor fills the tank , and the locker switch lights up as well - but stays lit up whether the locker switch is in the on or off position. The locker switch itself works fine as the solenoid is actuated and the locker locks and unlocks wiht the air being expelled out the vent.
So, is the light supposed to be on all the time? Seems to me it sould only come on when the locker switch is activated.
Any ideas? Did I wire something backwards?
Thanks
Louis
The locker switch lites up only when locker is engaged. So you have the compressor hot to your locker switch lite - somehow or the compressor and locker are both on a once. Should be an easy fix.
Think you made a mistake in the wiring somehow.
Cannot remember what was wrong when I did mine (6-7 years back) but can recall a search to correct it.
Was a matter of just two connections that had to be the other way around.
