I'm installing a used set of ARB steps (ARB part 4411010) on my (RHD) 1994 HDJ81. Seems like the u-bolts interfere with the brake lines.
The [short and sweet] ARB installation guide says to use a longer bolt with spacer for brake line bracket in the spot where the front u-bolt interferes, which should work fine.
But the rear u-bolt hits the lines where there is only a plastic "push in" clip, thus no bolt. The guide says to use an adhesive foam pad. Huh?
Has anyone done this and can point me in the right direction?
Thanks,
A.
Thanks,
A.
