ARB problem
Kamloops, BC Canada
Website
www.shopraddcruisers.ca
First day without rain around these parts and I have noticed under extreme power there is a clicking coming fromt he rear.
Dumped the fluid to find a nice grey metalic coloured diff fluid.
ARB housing is cracked were the allen head is inserted. Trying to pull the centre pin to pull the axles and put in a used unit for him to get home with.
Customer has a couple hundred miles and rather chance the unit grenading I will pull it and swap in a unit kicking around here.
How the heck do I get that pin out? Pulled the retaing bolts and nothing, even used the pursader.
Rob
Oh boy, they provide a tool for that, a little 'L' shaped thing that looks like an allen wrench. It's got a small threaded end on the long side, best I remember, and it's to be screwed in to the pin's corresponding threaded hole to act as a handle for pulling out the pin.
I just went to try to find one so I could give you the size but mine's gone someplace.
I tried a screw and it caught but would not pull out, the ARB was toast anyways so I used the BFHammer and pushed it out.
Maybe the housing was tweaked and torqued the pin???
Anyways its out and I am dead tired, time to hit the sack.
Thanks again for the help.
PS.....
Hudge thanks to Steve (AKA Poser), Steve called me on his own dime and talked me through the deal. I really wanted expert advice as to what I should do with the unit, he said it needs to come out or it may grenade on the customer.
I will sleep better knowing they are making the trip with a good solid third in thier truck.
Rob , the 2 arb's you sent me have been working flawless for 3 years. I would not hesitate to run the " ones layin around " your shop at all. You got any more fer sale ? I have a sapre case I could send you for the cracked one.
No such luck, you got me at a time when I needed cash.
Wish I had those ARBs still, glad to hear they are serving you well...
