Arb mini compressor location
Oregon
After searching I haven't found much info on best location to mount an ARB compressor. I am using the mini for the front and rear lockers only. Where are those who have this setup mounting the compressor?
Thanks
I fabricated an aluminum mount for mine. Passenger side front fender. The arch of the wheelwheel requires you to make a mount if you want the compressor to sit flat, although the compressor (unless oil lubricated) doesnt need to sit flat.
I used the Slee mount. Typical Slee quality but the mounting studs were a bit short for my liking and the installation instructions lacked details. I decided NOT to use their aux manifold as suggested on the site and found I had plenty of space for the solenoids.
Here is mine
sorry it's not a good close up
Man, TCH2FLY thats well compacted.... I used the area on the right fender behind the air cleaner as LandyLover stated... lil more breathing room.......
Thanks
I manage to put mine in left rear quarter behind plastic cover, so it is completely invisible. Let me know if you need any images.
