ARB Locker install
If there would be a money issue regarding the second locker, then I'd do what osotel says. Get an autolocking unit of some sort in the rear and use the ARB in front where you want more control over when it is locked/unlocked.
You'll probably get more use of a locker in the rear, since there may be times you'll have the wheels turned and may not really want the front locked, but you could almost keep the back locked anytime you are off pavement.
Hi All:
which rig are you speaking of? Your 80 Series or the '82 FJ40?
What is the intention of the rig?
For general purpose use install the Air Locker in the rearend of the TLC. If you are building a hard-core off-roader then install it in the front axle and procure a 'locker for the rear axle (such as another ARB, a Detroit, or a "lunchbox locker" such as the Lockrite, EZLocker, or Aussie Locker.)
Good luck with your rig!
Regards,
Alan
Put it in the front unless you plan on driving it daily
